i run mine with no expansion bottle.runs fine.pressures not an issue.also run it with no thermostat,as they do run hot.but so do all v's.i'd suggestremoving thermostat,and blanking hose off.i run mine like that ,and havent had a problem .before that rear cylinder used to run too hot,and bike always
seized on rear cylinder.nsr's are rare,but if you can.get hold of some mc18 barrels and heads,and chambers.the difference they make is unbeliveble.the engine runs cooler ,bigger port size,better flow and more power....
tlr is running with blue flame cans,tre unit,modded air box,and yoshi box ecu re writer![]()
