For road use - brakes more than engine
This is my spin on non-trick, regular road-riding. Works for cars too, apart from the front/rear thing.
Best braking aid is your eyes, for observation ahead of you, to help you anticipate.
Brake pads are much easier to change than engine parts, so use your brakes.
Brake in a straight line.
Decelerate by closing in the throttle. Change down each gear when you get to the appropriate speed, blipping the throttle at each change. This gives smooth changes with "mechanical sympathy" for the bike
If you need to stop more quickly, give the front a squeeze and change down to match your speed. You'll just know this instinctively, after a while, and won't need to look at your spedo or anything
Same advice as everyone one else, front brakes with a touch of rear, if required.
Good idea to give the rear a good try out, every now and then, to check it out and avoid it siezing up through lack of use. You can do this at low speed.
In a car, I brake, then double-declutch on the down shift or sometimes, just blip the throttle while passing through neutral, to equalise the engine and shaft speeds.
Roy Price - May the fish be with you! ®
