Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Thread: VT/VTZ engines and the fuel tap
    9th March 2004 - 20:16
    Trumpton triple
    North Shore
    Right, just got my VTZ back with a new (2nd hand) engine in it. Had a quick chat with the mechanic before I rode off, and he mentioned something interesting that might be handy for VT/VTZ owners, especially the older models.
    Apparently, leaving the fuel tap in the open/run position for extended periods (e.g. overnight etc) when the engine isn't running, has the potential to screw your engine something chronic - the big end goes, basically.
    If that happens, you'll almost certainly need to replace the engine, which is what I've had to do twice. The fuel tap is now the no.1 suspect for both of these blow-ups
    The bikes are supposed to have a safety feature to stop this happening, but it doen't always work. So the lesson is: always turn off your fuel tap when not runing the bike.
    8th August 2004 - 17:16
    1999 GSXR1100W, 1975 CT90
    Upper Hutt
    Could this also apply to other bikes?
    25th October 2002 - 17:30
    GSXR1000
    *sniff sniff* smells like bullshit to me. Did he give you any reason why petrol in the carbs can cause your engine to blow up? On two-stroke engines you should switch the full tap off, to avoid flooding, not to avoid bowing the motor up.
    Or maybe he's onto something................................
    26th February 2005 - 15:10
    Ubrfarter V Klunkn,ffwabbit,Petal,phoebe
    In the cave of Adullam
    Well, a lot of Jap bikes don't actually have an OFF position. They're controlled by a diaphragm off manifold vacuum and only have ON RESERVE and PRIME (and jolly annoying it is too).
    As to why : well I don't know , but maybe on a V Twin where the carb is often physically higher than the inlet port, if the carb flooded, and the fuel ran past an open inlet valve, it could seep down past the rings into the sump, diluting the oil and reducing its effectiveness? Maybe ?
    Quote Originally Posted by skidmark
    This world has lost it's drive, everybody just wants to fit in the be the norm as it were.
    Quote Originally Posted by Phil Vincent
    The manufacturers go to a lot of trouble to find out what the average rider prefers, because the maker who guesses closest to the average preference gets the largest sales. But the average rider is mainly interested in silly (as opposed to useful) “goodies” to try to kid the public that he is riding a racer
    GSXR1000
    That's the only possible conclusion that I could draw as well Ixion, the only way the big-end could be affected. Anyone else heard of this problem, surely it would be well documented if it did exist?
    13th January 2004 - 11:00
    Honda PC800
    Henderson -auckland
    El Dopa ol son--The advise offered to you was (I believe) specific to YOUR bike.
    your carb needles are pretty worn and your fuel tap is a tadd dodgy.
    What's happening is whilst the bike is standing fuel is indeed running into the sump and your bigends are sitting in a pool of petrol rather than oil.
    I'd almost suggest you fit one of those big lawnmower taps inline from your tank then turn the tap off and run your bike dry of gas.
    Only applies when you leave it standing for long periods
    -In case anyone wants to flame me--I know the bike I know the mechanic and I know the situation almost as well as Mr Dopo Himself.
    3rd October 2004 - 15:45
    Africa Twin DCT.
    Australia 4507
    Quote Originally Posted by El Dopa
    What can also happen if fuel gets past the needle seat is fill the cylinder if the inlet valve/valves are open which then can hydraulic and bend a conrod or worse... Depends if it is a manual or vacuum operated fuel tap,i seem to remember CBX's could do the above,so it was reccommended to turn the tap to off when not in use. ???..I remember a mate with a mexico escort who did some heater mods and wondered why the wheels were locking up when it was towed trying to restart it,a heater hose had been connected to the inlet manifold filling the cylinders.
    Trumpton triple
    North Shore
    Quote Originally Posted by FROSTY
    El Dopa ol son--The advise offered to you was (I believe) specific to YOUR bike. Your carb needles are pretty worn and your fuel tap is a tadd dodgy.
    Yes, but mine is probably not the only clapped out old VT on this site. Anyone else riding one might want to have a look at their fuel tap and carbs, and possibly save themselves some expensive hassle. That's the only reason I was posting it.
    And just to clarify, this wasn't a backhanded crack at the mechanic. I have NO problem with him or his work.
    Trumpton triple
    North Shore
    P.S. If that isn't a bloody good reason to ride it all the time, I dunno what is.
    Honda PC800
    Henderson -auckland
    Never thought it for even a nanosecond mate---honest injun.
    But ya do make a good point--and I guess it doesn't just apply to VT's
    30th September 2004 - 20:08
    Tojo and nothing. Damnit.
    Brighton, UK
    Hrrm.. My fuel tap is faulty for sure, it pisses gas with no vacuum applied to the vacuum hose that should prevent it. Never thought it would do that, makes a hell of a lot of sense really.
    I'm off to the garage now to turn off that tap.
    And I'll do an oil and filter change tomorrow.
    Mr Dopa, what were the signs of your engine failure(s), ya know, before it went boom..
    26th July 2005 - 12:12
    Newdlands, Welly...
    Quote Originally Posted by limbimtimwim
    Haven't you done that oil change yet ??? You norty boy !!!!!
    24th September 2004 - 06:46
    '76 CB550 Super Sport
    On the road to nowhere...
    I've left my gsx750et tap on prime overnight once and emptied the contents of the fuel tank into the sump. Wouldn't turn over at all. Needless to say I check the oil level and fuel tap before EVERY ride on it now.
    22nd April 2005 - 20:01
    Guzzi Sport 1100
    hamilton
    fuel tap leaks
    This problem happens to the GPz900r, the fuel tap becomes faulty and doesn't turn off completely, the carb needles then let the float bowls overflow into the engine. Then when you try to turn it over the next day the engine makes a very loud bang, and you've got yourself a bent conrod. This usually happens to the No 1 cylinder.
    Go to the GPz900 website, and take a look at the photos of this.
    Trumpton triple
    North Shore
    First time, nothing until I was riding along one fine day, and the engine randomly decided to spray hot green cooling fluid all over my crotch. Fortunately I was wearing my asbestos underwear.
    After that, no power and a ride home in Frostys van.
    Second time. Well, with hindsight, the first warning sign was probably when the engine wouldn't turn over. I had a quick look at the carbs and the rear one was all gummed up and sticky with leaking crap all over it. Being a dickhead, and at the time undereducated in the ways of carbs, I wiped it off, and managed to jumpstart the bike. Sweet. As soon as the engine was running again, I conveniently forgot all about the carb and the muck (cos there was this ride I really, really wanted to go on). Halfway through the ride, the engine blew up again. Doh.
    So, if she won't turn over, have a look at your carbs. If they're covered in crap (especially the rear one), that's your first sign.
    Then, have a look at your oil level. If it's higher than it should be, it's not because the pixies have been filling it for you, it's because petrol is leaking into the sump.
    The engine is probably (??) salvagable at this point, but only if you don't ride the bike. Dunno what the fix is, but it probably involves draining/stripping out the pistons and cleaning everything up.
    DISCLAIMER: The above is hard won recent knowledge and is probably wrong. If it is, would someone wiser than me correct it.
    EDIT: I will also be looking inot replacing the fuel tap ASAP, and possibly the carbs, if it isn't too expensive.
