Page 9 of 9 FirstFirst ... 789
Results 121 to 123 of 123
Thread: Radial engine bike by Jesse James
  1. #121
    25th October 2002 - 17:30
    GSXR1000
    This one uses the same engine, albeit in a different setup. I like the first one (believed to be a Jesse James design) better as the engine is mounted the 'right' way.
  2. #122
    24th September 2004 - 06:46
    '76 CB550 Super Sport
    On the road to nowhere...
    Quote Originally Posted by Jim2 View Post
    Rotaries and Radials are UTTERLY different concepts.
    Rotaries have a "piston" that is shaped like a triangle with convex sides that spins around in a circular combustion "chamber" on a central bearing. Mazda's latest rotary has the ports on the side of the chamber allowing for better exhaust scavenging, better sealing and higher compression for a much higher power output.
    Not all rotaries Jim...
    http://en.wikipedia.org/wiki/Rotary_engine
    http://www.keveney.com/gnome.html
  3. #123
    31st August 2007 - 19:50
    1995 harley davidson low rider
    Talking hmmmm
    so what do you do, do you have to tie your hands to the handlebars in order to hang on.
