I'm getting rid of my day 2 pocket bike. Has been absolutely thrashed. Rear tyre is nearly worn out. Front tyre is flat can be pumped up but loses air withen short time. The pull start broke so I welded the clutch up and you have to push start it to get it going. This actually gives it really good pick up with no clutch slip when you open the throttle at low revs. But its easy to nut yourself starting it and you have to stall it to stop it. I lost the footpegs so I welded some improvised ones on (10mm allen keys). The front forks have been bent when I crashed into a building but have heated and straightend them. No plastics except the main body bit which is pretty smashed anyway. Believe it or not it still runs pretty well. After a box of tui for it. Located in Papakura
