I heard a cheeky rumour that older bikes have rubber seals and bits inside the engine that don't like synthetic oils. Could be complete horseshit though, but sounds plausible. Old bikes and mineral oil just seem to be related somehow.
'Course that's off-topic, as the Teapot is quite a modern motorsickle.
How many km's on the bike? Don't go to a fully synthetic untill it's well and truely run-in. Myself, unless it's a high revving thing, I wouldn't bother use full synth, I use semi-synth in my bike, Castrol GPS.
Cheers, Jeff.
Yea The katana has done 20,000km and is a 2004 ,And as far as i know its only been run on mineral oilso yea ive brought some Q8 semi synthetic and put that in WOW what a difference in the smoothness of using the clutch
Havent seen you around on your cb do you ride through central wanganui much ? bloody nice colour by the way![]()
This advice only applies to the case where one might change from a mineral oil to a specific type of synthetic oil in a older engine that has run mineral oil for a long time.
Synthetic oils that are PAO based can cause deposits that have accumulated in an engine run on mineral oil for a long time,to loosen and potentially block oil passages.
PAO based synthetics are increasingly uncommon.
Switching between synthetic and mineral oils,or even mixing the two in a new engine will not cause any problems at all.It will keep the internals nice and clean.
