Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Thread: Wierd Engine problem
    13th May 2003 - 12:00
    Thinking
    Around
    I have a very weird problem with my new KLR650 2008, 5000kms.
    The problem appeared two weeks ago when I started the bike (start of a 800km trip) the bike wouldnt idle and when It was diffulcult to restart.....even backfiring, I got the bike going and decided to continue, the bike ran well until about 160kms when it spluttered and coughed (like it was running out of gas) I turned it on to reserve which didnt solve anything, I filled up with a new tank of gas and continued, the problem didnt go away, I stopped and checked things out and all looked okay, tired to start the engine and again backfire etc, when I got it going it was running fine and I continued, I arrived in Wellington and thought maybe it was a clogged jet or something.
    two days later I started the bike, no probs and started the return trip, all was good until about 100 kms when the problem started again, it ran crap for about 50kms then was fine again, then another 100kms it turned to crap again.
    I got home and took it to the dealer, they werent sure what it was so I left it with them, even though they couldnt look at it for a week, I ended up collecting it yesterday so I could get it ready for my south island trip next week (the dealer has it booked in for a service in 5 days) I took it for a ride to see if it was the same and after 100kms ish, the problem returned. I took it into the dealer and he came out to investigate and wouldnt ya know it the bike was running sweet again.
    Im lost, no idea what it can be any one got any helpful ideas for me please ?
    Ive run out of fucks to give
    5th August 2005 - 14:30
    Have seen similar on a new outboard with a piece of random plastic in the float bowl.
    Quote Originally Posted by Tank
    You say "no one wants to fuck with some large bloke on a really angry sounding bike" but the truth of the matter is that you are a balding middle-aged ice-cream seller from Edgecume who wears a hello kitty t-shirt (in your profile pic) and your angry sounding bike is a fucken hyoshit - not some big assed harley with a human skull on the front.
    27th March 2006 - 10:29
    Burglary capital of Unzud
    I've had similar over the years including it being intermittent. But nothing quite like that.
    Once was a bad plug on a DR500 (well I swapped it, and the problem never returned). For that, the amount of throttle didn't make much difference but was worse at higher revs.
    The other was water in my tank, and this was also intermittent. When I braked or went down hill I think there must have been water in the tank that got sucked thru the petcock into the carb. Normal driving and acclerating was fine.
    Quote Originally Posted by Albert
    Two things are infinite: the universe and human stupidity; and I'm not sure about the universe
    3rd June 2005 - 15:20
    81 katana 650 fighter.
    West!!!! (Auckzorz)
    wrong heat plugs......
    but more likely fuel problem.....
    drain the bowls...../ pull ya carbys apart...
    mind you the backfiring is odd.....
    makes me suspect more the buggered plugs scenario and/or the plugs are incorrect heat.
    i would have said timing had maybe slipped but that makes no sense because that wouldn't come right by itself.
    possibly crook CDI
    pull carbs apart....clean /replace plugs.
    1-2 hours total....then all is well.
    better than fluffing about...out with ze toolz!
    SM
    9th June 2005 - 13:22
    Sold
    Oblivion
    Do the easy bits first. Check the battery connections then put about 50-100mls (depending on size of tank) of Methylated spirits in the fuel tank, to clear any water out.
    How long had the bike been sitting before you bought it? Cheers John.
    24th June 2004 - 17:27
    So old you won't care
    Kapiti
    Thats good advice - check the battery connection, plug lead connections and drain the floatbowl if possible and tip a little meths into the tank...
    Thinking
    Around
    Thanks all, my research keeps pointing to the carbs.
    I did the battery check as well as output, its running at 13.8 volts which is good.
    Only thing left is the fuel/carb, the bike is new and wasnt sitting more than a few weeks so shouldnt be water.
    will see what the dealer finds, hopefully it will be fixed cause me of to the south island next week
    14th January 2005 - 21:26
    NZ
    My engineering methodology is kicking in - since it is new, it could be a manufacturing issue - piece of swarf somewhere it shouldn't be (like the float bowl suggestion) or a gasket that wasn't quite done right or a vacuum line that missed out on getting clipped on securely....
    It's disgusting what gets let thru so called "quality" control sometimes!
    EDIT: check the earth connection to engine....
    Sold
    Oblivion
    Quote Originally Posted by allun View Post
    I agree but while it is intermittent it still comes in at seemingly regular occurrences IE: 100km into a journey, sounding more like fuel system fault!
    Could be heat induced electrical dry joint.
    There are some long long roads between nothing down here Quasi, hope you get it sussed before you leave! John.
    Thinking
    Around
    im sure you got a trailer
    Sold
    Oblivion
    Quote Originally Posted by Quasievil View Post
    Ahh grasshopper, trailer very handy but best to avoid need in first place! John San.
    19th November 2003 - 18:45
    KTM 690 DUKE R
    Auckland - unavoidably...
    Have a look at the plug, had crazy things happening to my bike which smelt like carb problems but ended up being the electrode on the spark was shot. I know its only new but a spark plug should be an easy fix?
    20th May 2007 - 12:04
    various
    HB
    Sounds like a CDI problem. Poor soldering on the PC board inside the CDI. As new you should not open as this will bugger up the warranty. Also possible that there is a poor connection from the CDI or on the way.
    Good Luck!
    May the bridges I burn light the way.
    Follow Vinny's MX racing on www.mxvinny.com
    3rd February 2004 - 08:11
    Wallaceville, Upper hutt
    The '08s are having a few electrical problems caused by wires chafing under the tank. With my one it showed up as the left indicator (only the left) not working. Motorad found a wire with the insulation rubbed off.
    Have a look at http://www.klr650.net/, lots of info there
    (PostalDave on ADVrider)
    24th August 2006 - 18:00
    ZZR1100 D7
    Counties
    +1 I have heard the same wiring thing too. Not up to the usual Kawa attention to detail.
    If it is not this then the only other thing not mentioned so far is the carb icing. Does the CVK40 have the water pipe de-icing system on the KLR?
