Page 1419 of 2773 FirstFirst ... 4199191319136914091417141814191420142114291469151919192419 ... LastLast
Results 21,271 to 21,285 of 41593
  1. #21271
    17th September 2013 - 01:07
    SWE
    I think it's not totally unimportend since engmod uses it to calculate duct volume to calculate CCR?
    No, not totally. That's why I put it in "".
    But sims and dynoruns (made by wobbly I think) have confirmed that the transfer entry:exit ratio has very little impact on power. So it was somewhat a "isolated" comment from my side.
  2. #21272
    I thought it would make for interesting results doing a Wobbly exhaust port duct on a very high performance engine - something much better than the best HRC could do. So what better to use an Aprillia RSW125 as developed by Jan Thiel?
    It makes for interesting results:
    Attachment 318565
    Thanks for the graph, Neels. Could you tell us the nozzle % on these both curves? I guess it's 75 on the red one, but what is it on your RSW model?
    With my model (which is built entirely on internet information, as I have never gotten my hands on a real RSW or RSA engine), I get the following:
    as a start, I put the minimum diameter in the middle of the exhaust port and varied the nozzle diameter in % of the actual exhaust port area
Name:	nozzle percentage.png
    Quite an improvement, but I guess most of us were already aware of that potential.
    Next, I varied the position of the nozzle. I also found that the best value was 1,5 times the bore diameter, with 1,25 times about equal.
    Interesting about my results is that the position of the nozzle does not so much add more hp, but fills the midrange dip quite remarkably instead.
Name:	nozzle position.png
    In combination this gives a really nice improvement.
Name:	nozzle position and percentage.png
  3. #21273
    SWE
    Haufen, great results and presentation.
    Have done something similar in the past, but "by accident", so wasn't looking for the right things and details.
    With the "1.5 x bore" duct length we have one more rule of thumb to add to our toolbox trying to improve our different types of machinery.
  4. #21274
    Attachment 318565
    Impressive improvement on what was probably the pinnacle of 2T development. Awesome software Vannik, and Wobbly - well done
  5. #21275
    The plate added to the 3G3 TZ350 cylinder to accommodate the long stroke crank was in 6061 alloy.
    This is needed to be compatible with the plating process - but you need to tell your plater this is the material/weld used.
    Of significance though is the fact that the plate is thicker than needed, and that it is thru bolted at all 11 stud holes whilst welding around the bore
    and the water jacket.
    I also took the opportunity to completely change the water flow.
    The plate has only 4 - 12mm water exit holes above the Ex ports.
    With the water inlet from the pump into the top back of the cylinder, all the cold flow is forced over the transfers,around the bore,then over the Ex duct and up into the head.
    Then it travels back ,over the inserts, to the rear again and out at the highest point.
    A small 3mm hole in the plate at the highest point of the cylinder allows trapped air to get out, into the head water jacket above.
    Put large chamfers on the plate/bore faces, so the weld has good deep penetration, then the bore can be re cut without removing any of the existing bore face
    and the top can be cut before plating, to give the correct deck position.
  6. #21276
    23rd November 2014 - 22:11
    used to race TZ350 and Rotax
    London , UK
    Many thanks Wobbly for all the info about plate and water jacket mods. I've be following your posts on the TZ400 with great interest. I was going to fit the head the standard way around, but I'll be checking to see if it will fit on the G chassis with the thermostat housing towards the rear now. Thanks for your help, it's much appreciated.
  7. #21277
    TZ400 Water
    I cut the thermostat housing off and welded a thin plate over the top.
    The std Yamaha thermostat is junk - it opens at way too high temperature, and from memory the head isnt symmetrical so wont go on backward.
    Now I use a proper bypass thermostat that starts to open at 42*C and with the larger pump impeller the 400 sits on 50*C all day.
    The water outlet to the radiator on the back of the head, is the original inlet fitting.
  8. #21278
  9. #21279
    Pictures of the Exhaust dam.
    This is a model of the exhaust port dam.
    TeeZee, the Mach numbers are telling you exactly what you need to know. The port layout as it stands with the huge width above the transfers is operating like a T or 3 port, thus the Mach numbers for ExMach 1 are too low as I have found most ducts taken down to 75% area at the flange will approach 0.8Mach - and this seems to be the best compromise for power.
    EngMod2T simulation and engine performance analysis.
    Back story covering the development of the dam and using Engmod2T to analyse how to develop it.
Name:	Mach Traces.JPG
    After analyzing the mach numbers in the exhaust duct using Engmod2T we had a plan for the new exhaust duct.
Name:	RG50 Exhaust Duct A.JPG
ID:	318592 Click image for larger version.
Name:	RG50 Exhaust Duct B.JPG
    The new exhaust duct requires boring the existing over size duct out and pressing in a new smaller nozzle shaped duct. Chambers made a fly cutter and using Team ESE's rattly old mill drill with a bit of careful work he manged to make quite a neat job of boring the old duct out.
  10. #21280
    London , UK
    Thanks Husaberg for the links, only problem is that I should be getting up now, but haven't slept for the last few hours reading and digesting. All for a good cause though.
    Wobbly, looking at the rear of the cylinder water entry, how do you get the water to flow around the outside of the water jacket ? It looks like it would flow straight between the the barrels to the exhaust side. Is there a baffle or restrictor. I really like the cnc water pump impeller, that must almost double the flow rate, nice. Thanks again gentlemen.
  11. #21281
    Quote Originally Posted by paul gane View Post
    I missed one
    http://www.kiwibiker.co.nz/forums/sh...post1130929996
  12. #21282
    Anything has got to be better than std Yamaha which is like putting a flat plate on a bucket with an outlet on one side and squirting a low powered hose in another hole.
  13. #21283
    do my eyes decieve me.. or am i just getting old?
    Ryger production is running in high gear in order to meet the CIK regulations.
    Attachment 314432Attachment 314433
    Frits,isnt there something missing off the first picture, which sits under the carb on the front of the casings with water pipe type connections?
  14. #21284
    TZ400 Water
    Yes, the std TZ350 cylinder has a thick wall between the cylinders that has a hold down stud tapped into it from above.
    There is only a small water flow gap down low over the inner transfers, so water is forced to flow around the outsides as well.
  15. #21285
    5th September 2015 - 07:44
    2001, Aprilia, rs250
    Holland
    What you don't see is the cover the crankcase ventilation which was a separate part of the engine. This original design was not approved by the CIK/FIA. Ryger had to adjust this design. The crankshaft ventilation has now become an integral part of the crankcase.
    The Ryger concept is completely accepted by the CIK/FIA and the engine seems to be homologated.
