Page 2229 of 2773 FirstFirst ... 12291729212921792219222722282229223022312239227923292729 ... LastLast
Results 33,421 to 33,435 of 41594
  1. #33421
    3rd February 2004 - 08:11
    Wallaceville, Upper hutt
    Has this been mentioned here before?
    http://www.2t-racelab.com/2012/02/kawasaki-x-09.html Neat looking, unique engine configuration but in the end not fast enough
    (PostalDave on ADVrider)
  2. #33422
    Here’s a pic of a TM 100 cc reed kart engine with piston & cyl removed. Direct drive, air cooled and used for sprint kart racing.
Name:	TM 100 smoothed cranks.jpg
    Someone has put a lot of time into the bottom end, blending out the cases and, interestingly, radiussed the inside edge of the crank webs. Not sure if this might be of any benefit, but could/does offer the following:
    1. Increases crank case volume
    2. Lightens the crank and reduces its flywheel effect (2nd moment of mass). The opposite of what has been done elsewhere.
    3. Reduced the Cd of gas flow into and out of the crank cavity, particularly as this is a vertical reed engine.
    4. Perhaps improves the lateral flow out of the crank cavity towards the transfer entries
    5. Adds remote volume, at the bottom of the case cavity, maybe making the transfer of this extra volume less accessible.
    Anyone seen this and would it be advantageous in certain applications? I do know there are a shitload of other variables involved, that need to be taken into account. I also appreciate that there are no simple universal answers for 2 strokes.
  3. #33423
    I'd still advise caution.
    Thanks for the heads up.
  4. #33424
    Another question:
    Is there some way to remove nicasil without machining?
    Rgds
  5. #33425
    Another question:
    Rgds
    I thought it gets stripped with nitric acid?
    Yow ling has done it.
  6. #33426
    Ken , here are some thoughts on the TM100 kart mods.
    The crank radiusing probably has more positive effect on the intake Cd as alot of the flow from the vertical reed orientation is directed straight into that area.
    In a 100cc kart engine , the reduction in inertia would have more positive effect on acceleration , than the negative effects of the in cycle speed variation reducing transfer STA , as its
    easy to get sufficient areas with the low bmep produced.
    This type of mod was done many years ago on many factory tuned 100cc reed engines I have seen.
  7. #33427
    Ok, Im going to ask here, who has a set of late modle YZ 125 cases laying around? So I might measure them up. No asking questions, ok. You can have them back when Im finished.
  8. #33428
    15th August 2011 - 12:25
    CBR125TF
    Stinger question:
    Due to packaging and the location of my muffler (under seat) my stinger is ending up longer than desired.
    Would it help keep things in order if I step it back up by a tube size or two after the designed stinger length?
  9. #33429
    Research posts on nozels at baffle end and make the Stinger bigger.
  10. #33430
    CBR125TF
    Thanks for the search direction
    I’ve been reading this thread for a couple of weeks now but haven’t even cracked page 100 yet!
  11. #33431
    nozzle site:https://www.kiwibiker.co.nz/forums/s...s-engine-tuner
    Use the google "site:" search term to find what you need. Cut and paste the search line above to find the posts on the ESE thread that talk about stinger nozzles.
  12. #33432
    I posted these the other day in another thread.
    https://www.kiwibiker.co.nz/forums/s...post1131099423
    https://www.kiwibiker.co.nz/forums/s...post1129954861
    https://www.kiwibiker.co.nz/forums/s...post1129955411
    https://www.kiwibiker.co.nz/forums/s...post1130089030
    https://www.kiwibiker.co.nz/forums/s...post1130209099
  13. #33433
    13th September 2009 - 03:15
    all of em
    Oklahoma USA
    One thing I see in Ken's picture of the TM 100 is the big end bearing will be as cool and well lubricated as possible, not a weak link but ready for a hard life
  14. #33434
    Just me?........I find that intake very organic in shape.
Name:	A tree..JPG
  15. #33435
    Absolutely not just you.Anyway its not a tree its a bush.
