Page 2385 of 2776 FirstFirst ... 1385188522852335237523832384238523862387239524352485 ... LastLast
Results 35,761 to 35,775 of 41626
  1. #35761
    I thought you could base mill cylinder to tighten up squish and compression, just looked and that's part of case too.
    Best bet is make a longer rod.
  2. #35762
    28th August 2015 - 00:01
    1975 Hodaka Wombat
    Eugene, Oregon, USA
    What do the transfer passages and head look like. It might be easier to increase the stroke to tighten the squish if there is a squish area. Otherwise the pipe with high enough exhaust port timing will be the easiest. Rpm equals easy power. The limit will be crankshaft flex and the big end bearing. it looks like the crankshaft isn't an overhung design, so that should hold up.
    Lohring Miller
  3. #35763
    Thanks guys for the suggestions!
    The problem i se with an engine like this, which relies on crankcase compression the more port time the less compression. Together with the fact that it has a piston-controlled intake, it makes a bit of a Catch 22 without a proper exhaust.
    It has both a traditional piston-controlled intake port and a port through grooves in the piston to the transfer ports (which I have never seen before, perhaps common in these applications)
    I tried porting a bit and I can not say that I noticed any big difference. It is 1 mm in squish so you could do a little there, but it is not a quick fix to stroke it or make a new connecting rod ...
  4. #35764
    1975 Hodaka Wombat
    Eugene, Oregon, USA
    My articles on what we do to our industrial 26 to 30 cc piston port, race engines are here:
    http://namba.com/content/library/pro...015/October/#6
    http://namba.com/content/library/pro...2016/April/#5/
    Lohring Miller
  5. #35765
    Make new lower plate that holds the crank, offsetbore the mainbearings to alter to desired squish.
  6. #35766
    Get rid of crap cylinder replace with noncrap one.
    later on, realise i should have just brought a bigger saw.
    Divorce wife get a younger girlfriend and central heating.
    give saw to wife in the settlement.
  7. #35767
    I just love that chain saw.
    2Stroke Stuffing. Includes a brief run with the 24/7 on the dyno. Sounds much better with the longer inlet tract. Progress.
  9. #35769
    14th May 2021 - 12:08
    87 NH125 Honda
    Dunedin N.Z
    Modern 2T Theory
    Kia ora,
    I am wonder where I should go to read up on some modern 2T theory. I have read the performance tuning graham bell & tuners handbook but they seem mighty old - one suggested I buy a fancy scientific calculator.
    I've been following Alex on 2T stuffing youtube channel for years.
  10. #35770
    Quote Originally Posted by Joshua_ View Post
    Kia ora,
    Kia ora to you too, Joshua.
    HERE
    would be a good start.
    I can also recommend http://www.pit-lane.biz/t117p246-gp1...es-aprilia-rsa. It's a French forum, but the Aprilia-thread is largely English-spoken (Maori not so much, yet)
  11. #35771
    1975 Hodaka Wombat
    Eugene, Oregon, USA
    I've written many articles on high performance two strokes, especially for our small racing two strokes. One series is below:
    Lohring Miller
    PS The links in these articles don't work any more.
Name:	High Power Two Stroke Design.pdf
Name:	High Power Two Stroke Design Part 2.pdf
Name:	High Power Two Stroke Design Part 3.pdf
  12. #35772
    87 NH125 Honda
    Dunedin N.Z
    WooHoo!
    Lohring Miller
    Thank you very much - I'll read over these today :> I really appreciate the help. I accidentally asked the same question in a facebook group called moped army. I had seen a heap of cool projects on there but no one seemed to have much in depth theory going on. More bolt on go fast parts.
  13. #35773
    Kia ora, I am wonder where I should go to read up on some modern 2T theory.
    Kia ora Josh. Mostly stuff posted by Wobbly and Frits. Some Team ESE stuff.
    General secret 2S tuning stuff:- https://www.kiwibiker.co.nz/forums/s...tuner/page2000
    Some of the SuzukiGP-NSR110 info:- https://www.kiwibiker.co.nz/forums/s...tuner/page1680
    A whole lot more good stuff:- https://www.kiwibiker.co.nz/forums/s...post1131071959
    110cc Crank Shaft half way down the page:- https://www.kiwibiker.co.nz/forums/s...post1131050937
    Making a decent ignition from a Chinese aftermarket thing:- https://www.kiwibiker.co.nz/forums/s...post1131033289
  14. #35774
    1975 Hodaka Wombat
    Eugene, Oregon, USA
    A lot of what I know that I summarized in those articles was stolen from Frits and Wayne (wobbly).
    Lohring Miller
  15. #35775
    We all have the same goal here: promoting two-strokes. So spread the word Lohring; the more the merrier.
