Page 883 of 2774 FirstFirst ... 38378383387388188288388488589393398313831883 ... LastLast
Results 13,231 to 13,245 of 41608
  1. #13231
    The excessive intellect and or overly retarded will state the obvious and think its clever.
    Subtlety is the realm of the thoughtful.
    Problem lies in deciding what end of the spectrum one fits best to Frits.
  2. #13232
  3. #13233
    24th June 2013 - 20:28
    82 IT 175
    This is what happens when Flettner has no freeview.
  4. #13234
    They are looking good, I have my hat in the ring for a 100cc version of the casting.
  5. #13235
    9th October 2012 - 14:55
    CBR/FXR
    Cool. Have you ever had it apart? I had a Yohsi pipe that was straight through. But it had a little ring in the middle to push air around into the second perf. I removed the ring and the second perf and what do you know. No more reversion hole. Also you could try dropping the bottom of the Header 2-3mm from the bottom of the port (mismatch the port to header). I have also done this and it seams to be an improvement. Leave top and sides of the pipe flush or a tiny bit bigger than the exhaust port. Or of course it could be something different. my 2 cents.
    Thanks Rich,
    I am going after it. Will start with the muffler, then I like the header idea, and easy to trial. In simple terms I guess we are just trying to alter the natural frequency of the header. The header is not huge at the outlet, but bigger than stock and matched to the port.
    As an aside, Max's FXR engine (the Stu Hines build), is mildly ported and has a standard FXR header (with the weld ground out) that goes to an open exhaust/expansion chamber and as we know that is not too shabby!
  6. #13236
    Now that I have found a good calibration file that runs both injectors things are starting to fall into place.
Name:	EFI Test Bench 2 001.jpg
    I spent the afternoon using the oscilloscope to check and adjust the crossover and the minimum width between pulses of the injectors so they were in balance at peak rpm and getting everything done in about 180 degrees before transfer closing at any rpm up to 14,000.
    To get my head around it all I drew a picture of an injector pulse.
Name:	EFI Test Bench 3 001.jpg
    And marked out all the relevant timing events like transfer port opening/closing and marked out how many degrees the crank moved at different rpm for 1 - 2 - 3 - 4 ms.
    With ProCal running and the oscilloscope I could easily see at what RPM and TPS the injectors swapped from 1 to 2 and then 2 + 1. By making changes in the advanced calibrations menu I could influence when this happened and keep everything within about 180 degrees before the end point at transfers closing.
    The Ecotrons EFI system allows you to set the end point and the EFI cpu works out how early to start the injection pulse. So with the endpoint set at transfer closing the injector pulse will mostly happen during the transfer open period.
    It is certainly much easier dialing in this part of the setup on the bench with a signal generator and oscilloscope than on the dyno.
  7. #13237
    If the sleeve thing doesn't work, we will just lower the exhaust ports and re cast as an FOS cylinder.
  8. #13238
    Great stuff ....... this is really exciting Bucket building.
  9. #13239
Name:	EFI Test Bench 4 001.jpg
    Ok ... we now run on two injectors.
    But having climbed one hill I have found another behind it.
    I set the start =1 - after start =0 and warmup factors =0 so they would be neutral.
    For some reason the universal calibration adjustment has quite an effect while the same magnitude of change made to the Load Map does not have the same effect.
    I think there must be some other map bending factors in the Advanced menu that need setting to zero too.
    And also there is a peculiar problem that Speedpro mentioned, earthing the case of the EFI's CPU causes the Laptop to lose contact with the CPU and the motor starts grinding to a stop, starts straight up when the CPU's case is isolated again.
  10. #13240
    Glad I'm not trial blazing that path. I'm having enough drama remembering to set program auto on the Ignitech when trying to set the base. Just cut a woodruff key as got sick of trying to find top or 15and then re timing. But I missed the first time. Bah.
  11. #13241
    My fuel pump was erratic and mainly would not run at start.
    My understanding is that the universal calibration adjustment multiplies the result of all the map values and any other multiplication factors so it can have a HUGE effect. The other multiplication factors like "warmup" only multiply the values active in the table. Those table values may also be multiplied by a 2nd factor and then added to that previously calculated value. The 2nd multiplication factor does not multiply the result of the 1st calculation.
  12. #13242
    I was hoping your sleeve thing would work, but what should I hope for now?
    You know, I followed the same line of thought, starting with the full circumferential porting of a uniflow cylinder and then trying to eliminate the excess mechanics by pulling the exhaust end of the barrel inside out like a sock, so the piston could take over the sleeve's task.
  13. #13243
    On mine there is also a bottom mid and top rpm enrichment/enleanment factor that looks like its for bending the curve. I will have to have an explore to see what they do exactly and if they are the problem.
    It makes sense that there are different .cal files that come with different numbers and types of variables to chose from, for 4T 2T supercharged etc. There are also different .A2L files, and I suspect these contain the EFI programs algorithm and are configured by Ecotrons to match the hardware they are shipping.
  14. #13244
    The A2L files are the operating programme for the Motorola processor, I think.
  15. #13245
    Here's race one:
    I'll load up race two over night.
    And race 2
    Jolly good weekend.
    Richbans vid from Tokoroa ... great to see the other bikes and a neat piece of riding by Rich as he works his way up through the field.
    Team ESE riders 3rd and 4th in this photo, Richban is working his way through traffic to catch the lead group.
    Taken from ChrisC's photo thread. http://www.kiwibiker.co.nz/forums/sh...post1130648134
