Page 884 of 2774 FirstFirst ... 38478483487488288388488588689493498413841884 ... LastLast
Results 13,246 to 13,260 of 41600
  1. #13246
    I was hoping your sleeve thing would work, but what should I hope for now?
    You know, I followed the same line of thought, starting with the full circumferential porting of a uniflow cylinder and then trying to eliminate the excess mechanics by pulling the exhaust end of the barrel inside out like a sock, so the piston could take over the sleeve's task.
    Don't get me wrong, I'm going to give it a good go but, you know, it is nice to have an alternative up your "sleeve".
  2. #13247
    http://thekneeslider.com/jj2s-x4-500cc-2-stroke-update/
    http://jjsdesign.net/motocyklstudialny/
    500 4 2T - Very interesting but I won't be trying to make a Bucket Racing version.
  3. #13248
    Off to the foundry tomorrow
    Sleeve with piston. Sleeve ready for nitriding.
  4. #13249
    Richbans vid from Tokoroa ... great to see the other bikes and a neat piece of riding by Rich as he works his way up through the field.
    Attachment 290831
    Team ESE riders 3rd and 4th in this photo, Richban is working his way through traffic to catch the lead group.
    Taken from ChrisC's photo thread. http://www.kiwibiker.co.nz/forums/sh...post1130648134
    Yeah classic bad start from me. Cool little battle with Kel. About the same power. Just a little weigh difference and 2T V 4T. Great fun.
  5. #13250
Name:	Creasy Sleeve.jpg
    Ok, I am starting to understand this (I think), the transfers are cut into the sleeve and the piston uncovers them in the normal 2T way. And the top edge of the sleeve uncovers the exhaust port as the sleeve reciprocates up and down.
  6. #13251
    To nights effort was about trying to figure out if I have the right size injectors and if I can make them do the job in less than 360 deg at max rpm.
Name:	2 points the same on the TPS-RPM map.jpg
    Selected two points on the Alpha-N, TPS/RPM Load map and checked the screen gauges at 11,750 and 12,500 rpm.
Name:	11700 k 5.0ms.jpg
    Now FUELPW1 and FUELPW2 on my setup are different size injectors and don't have to have the same ms pulse width.
Name:	12340 k 4.8ms.jpg
    But I do expect that for two different RPM's with the same load (ie Alpha-N TPS Load/rpm map number 135.023 at 11,750 and 12,500) an injector would have the same pulse width.
    5ms at 11,703rpm = 351 degrees and for the same load at 12,500 rpm I would expect the pulse width to be the same.
    But here the pulse width has decreased as the rpm went up and 4.8ms at 12,500rpm = 360 degrees. This indicates that the injectors have maxed out and need to be bigger.
Name:	Increase size of second injector.jpg
    Increasing the number two injector from 330 g/min to 500 did the trick.
Name:	Minimum time between pulses.jpg
    The next trick is to increase the minimum off time between injection pulses. This is used to force the cross over between 1 to 2 and then 2 + 1 and to try and get everything done in less than 360 deg, or as quickly as possible, ie 180 - 240 degrees or so without cutting things to short for the injectors to get it all done at the higher rpm. Basically, the injector has to be on for at least 2ms and not more than 360 deg, so as the rpm goes up the window gets very small. Next time I might try a dummy map with a straight line just to make it easier.
    The whole thing is a bit of a fine balancing act.
  7. #13252
    As if these options were not enough already, are you able to vary the fuel pressure, too, TZ?
  8. #13253
    Yes I know, much more complicated than I first thought but makes sense as I get used to it. I guess I could vary the fuel pressure and I think there might be a map for doing that but the basic kit I have only has a simple pressure regulator. I will have to look into the possibilities of varying the fuel pressure, thanks for the tip.
  9. #13254
    Foundry day successful.
    From glue, beads and bodifill rubbish, to somthing usefull.
  10. #13255
    31st July 2005 - 11:15
    a shed full of crazy shit
    epic. Love your work
    Out of interest, could you even get close to the same quality (as your results). Using lost wax or foam??
    Cheers
    Brent
  11. #13256
    20th June 2012 - 00:17
    yamaha
    I have to admit this is frying my little brain watching this
  12. #13257
    I hope the Germans dont steal your IP Flettner !
  13. #13258
    26th June 2005 - 21:11
    Honda NSR300 track hack
    Pukerua Bay
    Loving your work Flettner.
    How do you go about the design of these are you using a flow analysis software along with 3d modelling or all empirical design?
    Cheers,
    -Sketchy
  14. #13259
    Things that you don't read in the Ecotrons manual but now we know for sure.
Name:	ECU Isolated.jpg
    ECU case is electrically isolated.
Name:	ProCal Connected.jpg
    ProCal software is connected and running.
Name:	ECU Case Earthed.jpg
    ECU case is earthed.
Name:	Procal Disconected.jpg
    ProCal software is dis-connected and has stopped running.
    The metal Ecotrons ECU case can't be grounded in any way when mounted to the bikes chassis, next time I will get the cheaper plastic case version and fit my own RF shielding.
  15. #13260
    . . . . and there will be 7mA of so flowing to ground. There was on mine.
