I know that using a torque wrench is heressy but at the risk of more derision I will mention it again.
I always use Loctite and a torque wrench on caliper mounting bolts. I have never had a loctited bolt seize upon removal.
I have known caliper bolts to fall out and brakes fail on 2 occasions (not my work). Both are on KB.
A torque wrench or loctite would have prevented this in either case. Anti seize wouldn't help one iota.
With a steel bolt and a steel nut/thread the bolt is designed to snap so as there is warning of a failure. This is a safety mechanism and is usually not available when a steel bolt is into an ali thread, as is often the case with caliper mounts. You may damage the fastener or the thread and be unaware of this. A torque wrench wont make you aware of it but it is likely to help prevent either of these in the first place.
I await the usual twaddle from the anti torque wrench brigade about how they just "know" when they have the correct torque etc - and look forward to more posts asking about heli coils and stripped sump plugs.
