unsure with a CRF but for my DR its rather simple
drain plug at the bottom or side of the sump - remove that and drain the oil
now the filter on yours is most likley different to mine but mine is behind a plate\cover on the kickstart side near the front - 3 bolts off and the filter will spring out spraying oil everywhere
- clean the filter housing out and put a film of new oil on any rubber\parts that will be sealing from oil leaks and replace the filter in reverse from taking it out
this is just a rough guide and will probably be rather different to your bike so wait till someone that knows your bike can tell you how to replace the oil filter
Cheers
Speeding has never Killed anyone. Ever. stopping suddenly, now that's what gets you.
