Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Thread: Yamaha Starting problems - Help
    7th July 2005 - 12:06
    North Shore, Auckland
    My YX 600 has reall trouble starting, if I run jumper leads from a car, it will start but after about 15 minutes of me swearing at it, and pressing the go button. I have tried the obvious (a new battery) but that did not solve anything other then the draining of a new battery. The lights don't flicker or get brighter when it revs when its going so I would presume that the rectifier is ok. Once its started and been running for 10 minutes, it will start again first pop, but not the next morning.
    When i start it from cold, its winds nicely untill the battery dies then it just clicks like cricket from the solenoid.
    I'm not to savy with these bikes yet so any suggestions would be great
    thanks
    Cibby play thing
    4th January 2005 - 18:50
    Massey ferguson 7495 dyna-vt
    Norfland
    bwwwaaaaaaahhhhhhhhhh.,......lmao lmao lma lmao lmao.....te hehehehehehehehehehehehehehehe....hahahahahahahaha hahahahahahahahahahahahahahahahahahhaahhahahahahah aha.....hehehehehehehehehehehehehehheheheheheheheh ehehhehehehehehehehehehhehehehehehehehehhehehehehe hehehehehehehehehehehehehehehehehehehehheheheheheh ehehehehehehehhehehehehehehehheheheheheheheheheheh ehehehhehehe hahahahahahahahahahahahahahahahahahhahahahahhahaha hahahahha......
    Given the short comings of my riding style, it doesn't matter what I'm riding till I've got my shit in one sock.
    Thanks mate, very helpfull.
    Cibby play thing
    10th May 2006 - 10:37
    Aprilia RSV Mille & Aprilia Tuono 660
    Torbay, North Shore, Akld
    Any further info ? Last service ? Replaced the plugs, coils, CDI unit ? Anything that could have a bearing on the problem.
    It needs an oil change but that shouldn't have too much affect, its not misfiring when its going so the sparks should be ok and visually look fine.
    Once its running, it runs fine as if it has no problems, its just the cold start that it won't do withoutthe help of another battery.
    Cibby play thing
    Norfland
    Quote Originally Posted by Postie
    any time...... lmfao
    5th August 2005 - 14:30
    So I gather from what you say, the battery seems to be charging ok?
    Like, in the morning when cold it winds over for say 5 or so minutes before it dies?
    If so how are you trying to start it?
    Quote Originally Posted by Tank
    You say "no one wants to fuck with some large bloke on a really angry sounding bike" but the truth of the matter is that you are a balding middle-aged ice-cream seller from Edgecume who wears a hello kitty t-shirt (in your profile pic) and your angry sounding bike is a fucken hyoshit - not some big assed harley with a human skull on the front.
    Quote Originally Posted by CaN
    yeah exactly that. I press the start button, all sounds fine but it just won't fire. It gets close after a few goes but then the battery starts to die, gets a couple more turns then the battery gives the ghost all together and the solenoid starts to click. A strange thing i noticed this morning is the rev counter climbing even though its not running the engine.
    The charging systems seems to be working as the battery stays charged when its running of course.
    Cibby play thing
    5th April 2005 - 12:57
    In between bikes
    Earth
    Assuming you got fuel in the tank and not switched off.
    Do you need to use the choke?
    Was thinking kill switch ... but then the starter won't kick over either.
    Coils?
    90% of the time spent writing this post was spent thinking of something witty to say. It may have been wasted.
    Quote Originally Posted by Flyingpony
    Coils?
    fuel tank is full, it does need choke and that was on but not flooding it either. Yep, kill switch was in go mode (about the only part of the bike that was)
    I am thinking of making it lightweight with help from Mr 12 gauge
    Cibby play thing
    So how are you trying to start it?
    The VFR had this problem too.
    Charge seemed fine, would hot start just fine, but wind over for 5 or 10 minutes (with breaks) from cold and most of the time was very hard to start or just wouldn't from cold.
    We found that if you attached a car battery it would leap into life, so we suspected the battery, say a cell had colapsed. Battery voltages seemed fine (to me) though both at rest, under load and during charge.
    Not sure we ever got to the bottom of it.
    We looked at all the usual suspects but the cold start technique made a huge difference.
    Use choke only and no throttle from cold. If you touched the throttle at all it wouldn't start.
    We later took it into Henderson Motorcycles and they tested the rectifier. Reconed there was ample charge going in, but insufficient coming out of the rectifier, not by much though. They replaced the rectifier and it was good after that. I say not sure we got to the bottom of, because there was one odd incident after that where the thing just died for several hours then came back to life, but I don't think it was related
    I know the VFR have a bad rep for eating rectifiers but this one was after market and as it seemed to have sufficient charge we didn't initially look there.
    its pretty much exactly that. If I connect it to the car bettery, it seems fine, I have tried 2 different and fully charged bike batterys with the same no go result from cold, but both were fine on the warm start up, maybe i will look around for a rectifier and see if that helps.
    Thanks CaN
    Cibby play thing
    26th February 2005 - 15:10
    Ubrfarter V Klunkn,ffwabbit,Petal,phoebe
    In the cave of Adullam
    Defective coils, or maybe CDI. Prolly the former. Maybe exacerbated by dicky starter motor/solenoid/wiring.
    The coils get a bit dodgy, internally bunches of the windings fuse together. They still put out enough voltage to fire the plug, but it's lower than it should be.
    When you try to start from cold, the starter load drops the battery voltage way low. And thus drops the coil input voltage, and , in turn the coil output voltage. Sparks not strong enough to ignite mixture in cold engine. Car battery works becos it's BIG. So, less voltage drop. Works OK when hot cos hot motor turns over easy, less voltage drop (and battery is warmed up too, that makes a big difference) . try cleaning all connections .
    I'd say also dodgy battery cpet u say u've tried sunsitution with a known good one.
    Quote Originally Posted by skidmark
    This world has lost it's drive, everybody just wants to fit in the be the norm as it were.
    Quote Originally Posted by Phil Vincent
    The manufacturers go to a lot of trouble to find out what the average rider prefers, because the maker who guesses closest to the average preference gets the largest sales. But the average rider is mainly interested in silly (as opposed to useful) “goodies” to try to kid the public that he is riding a racer
    28th August 2005 - 19:37
    MT09 Tracer
    New Plymouth Taranaki
    Quote Originally Posted by Ixion
    try cleaning all connections.
    Especially battery leads both ends, earth, coil terminals (weak voltage in = very weak voltage to plugs)
    Suck, Squeeze, Bang, Blow aren’t just the 4 cycles of an engine
    In between bikes
    Earth
    Have you removed the spark plugs and pressed the 'go' button while holding them against the engine casing?
    How big and beautiful were the sparks generated?
